mys13rocks »
https://forums.nicoclub.com/mys13rocks-u17520.html
Sun Oct 24, 2004 12:13 am
sea foam works great but theres also 123kit from berry man products ..1 spray intake.2 vacuum line and floor it. 3. poor b12 in fuel tank.should clean out the inside of the engine with thoughs steps.and also u should try buying circle earth grounding for better idle and throttle reponse. should cost no more then 30 bucks on ebay!the berryman products does these things-->step one cleans all the gunk build up in the intake throttle body and removes all build up. step 2. cleans intake valves ,pistons, exhaust valve, and exhaust headers. step 3 cleans all fuel sysytem delivery! that should do the trick!when i bought my car it drove like shat..so i did those things i mentioned above and everything works great now.when u do the vacuum line step u should be blowing black smoke out of your exhaust that means its working ..when it starts to blow white smoke then its clean. this does not mess with your sensors. when using this product u should use 91 or 92 octain!also u should change the oil as well for better results.
