Surging Idle
Doomed2Walk
Car: 2005 Subaru Impreza WRX STi WRBP on gold
I have a SR swap with the mods listed below, but my idle is surging and when I open the throttle too quickly it my car sputters and just runs terribly rich. Is this due to a vac leak somewhere? I checked everything out, but from the wastegate actuator to my boost controller brain, the hose isn't clamped, could it be a leak there? Thanks
Silvia007
Car: 93 Nissan 240SX SE Fastback
surging as 800rpm to 1-2k rpm then back to 800rpm? If that's so, check your coolant level inside your radiator.
JonPowell
Car: Cars, Music, My family
Also might be a dirty IAC valve, try cleaning it.
