Neil »
https://forums.nicoclub.com/neil-u15642.html
Wed Mar 22, 2006 11:45 am
with the tps unplugged it should drop to around 700-800rpm but only when its warm and after you flick the throttle a few times.
there's a bunch of posts already on adjusting the tps. I know because I read one for myself when i first got my sr and have written up the instructions twice already for other ppl since
You need a multimeter and a paperclip. With the TPS plugged in, unbend the paperclip and stick it down into the plug boot next to the middle wire. (+) lead of the meter goes to the paperclip, (-) goes to ground or neg battery post. with the throttle plate closed it should read between .35 and .5 volts. To adjust the TPS its held in by 2 7mm/Phillips screws. loosen them, rotate the tps to .45v or so, snug them back down. If the reading bounces around at all the TPS may be water logged like mine used to be. If its letting thru too much voltage or not enough and adjusting it doesnt help enough, its probly just plain bad.
this is a very opportune time to check your ignition timing. please do a search if you're interested in doing this also.
