nametakennow »
https://forums.nicoclub.com/nametakennow-u713.html
Mon Apr 24, 2006 1:14 pm
If you have not had the ECU (ECM) foam lining removed, get it done immediately. If your ECU is dead because of it, Nissan should replace the ECU free of charge. They may tell you your car is unaffected by the recall, but you may have the problem anyway, and unfortunately ECUs run $500ish. So, if you're not in the recall range and the foam killed your ECU, you're out $500 . Regardless of whether you're part of the recall, insist that the foam be removed. It's unnecessary, and, as I said, it may kill your ECU even if you're not in the affected VIN range.
I still think this is a MAF issue. Who told you it was your O2 sensor? Did they use a scanner to run the code? If they didn't, they don't know anything about how these cars work and guessed anyway (and incorrectly).
If this is not the foam lining recall, your MAF is busted. Sadly, these pieces aren't cheap either, a few hundred bucks. A dead MAF would explain your SES light.
So, call your dealer and give them your VIN to check for the recall. If you're safe there, run to Autozone and have them scan the code on the ECU (it's a free service). I suspect you'll see a MAF code. Order a new MAF from Nissan, it's a 5 minute install on your own, or an hour and a nasty labor charge if you have Nissan do it.
