supra injectors work!!! thanks guys!!
frosted flakes
i installed 3rd gen turbo supra injectors (440cc top feed low impedence) with a 10ohm 10watt resistor (from radioshack) on the power side (white-black wire) of each injector and it runs!!! i didnt have to modify anything other than swapping the rubber pieces. direct bolt on besides the wiring.
runs great. i still need to do some fuel tuning but i know im getting of plenty of fuel now from my 15psi run
so upgraded injectors for an rb20det is the supra injectors!!
klh6686
Car: '92 FB stock daily
'90 FB w/ RB20
'92 FB w/ VH45
EDIT:nvm i researched some more, thanks!
Modified by klh6686 at 4:05 PM 4/17/2005
Shahee1
Car: 1993 240sx w RB20DET
How do the resistors wire in??? Do you have pics that you can send me so that I can go the same route ... I have the same injectors, but did not want to place the injectors in cause I keep hearing different things about the impedence of RB injectors.
Carl H
yup, like i said they are a cheap and easy to find upgrade.glad to hear you got it working right, its not that hard to make them work properly.
BoostFab
Car: S13cp, S13fb, S14z
good to know your car is running good.
i have an extra set of fc rx7 460cc injectors made by denso, similar to the one frosted flakes is using, i need to get rid of them...let me know if anyone wants them.
i sold my car, now on with a new project
RB20DETodd
Car: 92 Nissan S13 coupe SE RB20DET
15 psi then dyno
frosted flakes
no 18-20psi then dyno
RB20DETodd
Yes, then go race Arron with the Red GSR up at quiznos, he just put on is Greddy turbo kit, and reassure him that the RB dominates
StricNyne
i got those rx7 they r brown right ? i want a rb20 fuel rail to use them on my 25, ne one know if they will work ?
Benz_200t
Car: Mercedes Benz W123
bro...which model of supra???1jz/2jz??
klh6686
'90 FB w/ RB20
'92 FB w/ VH45
Benz_200t wrote:bro...which model of supra???1jz/2jz??
7mgte, "bro"
