sjbsuperman1425 wrote:
My questions are as followed:
Does the S14 T28 have a built in oil restrictor?
If I get SS lines, do I get the CA lines and add a restrictor or not?
Do I use the CA or S14 Oil drain?
Oil restrictor is not built in, but IIRC most of the S14 turbo's weren't ball bearing. If it's a non-BB turbo, then the restrictor built into the 90° fitting coming out of the block is fine. If it IS a BB turbo, you'll need to buy a restrictor and using the stock oil feed line will be come VERY difficult.
GET THE SS LINES!!! I've done it both ways and it's TOTALLY worth the money. The stock hardlines are pain to work with. See above about the restrictor.
CA oil drain with the holes in the flange elongated so it will bolt up. I carbide bit on a dremel works decently well.
