wbrian63 »
https://forums.nicoclub.com/wbrian63-u91500.html
Wed Apr 02, 2008 3:37 am
I followed the instructions on page 31 of the SRS section of the vehicle service manuals for the 03 M45 found here on the site.
Simple as pie, and the light is out.
Quickie instructions for those that want 'em.
1. Turn key on.2. Once airbag light has displayed for 7 seconds, turn key off within 1 second.3. Wait more than 3 seconds4. Repeat 1, 2 and 3 two more times (three on/off cycles total)5. Turn key to on - this puts the system in diagostic mode.
Notes - the 7 second delay corresponds to the normal on-time of the airbag lights. Just switch the key off as soon as they go out - wait at least 3 seconds, then repeat the cycle.
There are a series of flashes that will indicate the source of the malfunction, but in my case, I really didn't care about the flashes, as I was the cause of the malfunction by disconnecting/reconnecting the passenger airbag.
Once you're in diagnostic mode, resetting the light will occur once you turn the key off, wait a few seconds, and turn it back on again - this puts it back in "user" mode.
