r34 gtr wrote:I believe they are made of different alloys. The Supertech is a low-silicon 26xx alloy (2618?) and the CPs are a high-silicon 4xxx alloy (4032?). The Supertechs will expand less, but will ultimately cause more bore wear because of the harder material. The CPs will be noisy, but ultimately last longer, I believe.
Disclaimer: I probably don't know what I am talking about.
Its the other way around with the materials, but otherwise its correct.
I would go for the supertech ones. Yes it is a weaker alloy in theory, but the 26xx material is really overkill for 99.9% of us.
The CP`s wont last longer, only in bad conditions (temp/knock), and if you have to much of that you deserve danger to manifold anyways.
I have gone Arias now because CP wont make pistons in 40xx alloy for me. (they dont make them in so small dimensions).
Supertech would also make custom pistons, but i chose arias.
