my12by60 »
https://forums.nicoclub.com/my12by60-u258835.html
Sun Dec 27, 2015 6:28 pm
I did two drain and fills yesterday using the Supertech gallon jugs labeled for Dex III compliance. First batch of fluid that came out was reddish-brown on a paper towel. I then drove about 12 miles, cycling through all the gears including reverse at various times. Then I did another drain and fill. The fluid looked a bit better, but still darker than the new fluid being added. My plan is to do at least two more drain and fills in the near future.
Is there a minimum amount of miles to be driven between drains and fills when using this method to refresh trans fluid?
As far as I can tell, this is the first trans fluid replacement that this car has seen. Current mileage on the car is 101,000.
