Desert Rat »
https://forums.nicoclub.com/desert-rat-u54558.html
Mon Apr 07, 2008 6:05 am
The frame under the truck is plenty strong to take the abuse. These trucks are a bit underpowered, and have just adequate brakes for heavy loads, so consider that when loading it down. I'm not familiar with the aftermarket spring packs you mention, but it sounds like they may work.
Another option is to source a set of junk yard springs from a hardbody or frontier and steal the second leaves out of it and add it to your packs. Air bags would also be a good alternative and would give you the best of both worlds - pump them up for load handling, turn off for empty driving. This would be a custom application, but wouldn't be terribly hard to install, especially if you have some minor fab skills.
