PandaS14 »
https://forums.nicoclub.com/pandas14-u20587.html
Tue Apr 19, 2005 9:47 am
Another thing to note that keeps ka's from being able to withstand high rpm beatings is the unbalanced crank. It's not a fully counterweighted crank, which means the higher the rpms, the worse the vibrations (harmonics) get. So even with a destroked ka, with the stock crank, you are still gonna shake your engine to death at sustained high rmps.
Here's a pic of a fully counterweighed crank versus a half counterweighted crank (like ours) from Devious' site.
So the bottom line is, unless you have a ton of cash or a full machine shop, you aren't gonna get the ka to sustain 7500+ rpms. Why must everyone be obsessed with making ka's rev to infiniti, instead of concentrating on a more attainable goal such as making power within the ka's rpm range? Do that first, then if you still aren't satisfied, try upping the redline.
