SuperDorifto's Overbuilt Kouki KA-T Build
WDRacing
Are the Godspeed catch cans filled with anything? I suggest steel wool if not.
superDorifto
Car: 1997 Eclipse Spyder - AWD/5spd swap in progress
1995 Q45 - 5spd swap in progress
1984 200sx hatch(KA-t swap) - 355WHP
1991/1993/1995/1997 240s - Dead
1982 200sx hatch - fixed/scrapped
No, I had my machinist add a draw tube and a larger plug on the bottom so I could seat the wool at the right level to act as a seperator membrane. He also added the push to connect fittings to the inlet/outlet tubes.
I shot him a message that i would need the second can modified, he was less than thrilled....hes a little grumpy over the holiday.
I've been playing around with the diagram, I think I can use (2)1 way valves and 2 three way tees on the VC side to allow it to flow both ways, and bypass the can when the manifold vacuum is working - this should keep the VC from re-drawing the blow by liquid into the VC.
WDRacing
You could always just go with a header mounted system. Easier for sure.
superDorifto
It would cost about the same too...Last time I checked summit kits were in the $40 range. It would still need the 1 way valve circuit to keep the low vacuum functionality off throttle.
Also if I knew up front that I would need to run 2 cans, I would have bought a fancy box like all the cool Honda kids like to run.
S2000 example
http://www.ebay.com/itm/Honda-S2000-S2K ... 8b&vxp=mtr
Generic VTA can
http://www.ebay.com/itm/BLACKWORKS-RACI ... 33&vxp=mtr
The only problem I see is that I def dont want to vent to atmosphere...I could prolly modify it to work, but I'm already halfway down the path im on. I guess I'll look into the header siphon tube for the WOT VC vent.
superDorifto
Some pics of the final mods to the manifold. I relocated the coolant return to the backside of the thermostat, there was an area on the backside of the waterneck that lets you tuck the connection behind everything. I just need to get an NPT plug for the old hole. I also mounted the MAP sensor, and tapped the hole for the PCV push to connect.
As an aside, it is way too cold to be working in an unheated garage.
WDRacing
All that time and money spent out there definitely warrants a propane or kerosine heater. When I used to do construction with my uncle...by construction I mean slave labor...he had a sweet kerosine heater.
Similar to this...
Only had to turn it on in short bursts. I just have one of those single head units that mounts on a grill style propane tank. Works pretty good for taking the edge off though.
superDorifto
The motor is currently in Foster's parent's garage, and he has a propane heater....I just need to get up the motivation to head over there and finish buttoning everything up.
Jmoore124
Car: 1995 240sx Ka-t
2003 Saab Linear turbo conv
(Sold) 1989 S13 red top
Just make sure you have GOOD ventilation with those things. They will keep you warm in the middle of a field on a cold day if they are pointed at you. But in a closed environment can cause some serious carbon dioxide issues.
PapaSmurf2k3
Site Admin
Yeah, they also don't exactly burn clean, so I wouldn't use them anywhere you're planning on painting. Propane is a lot better.
WDRacing
superDorifto wrote:The motor is currently in Foster's parent's garage.
I always forget you and Foster are buds. Is he a Dr. yet or what?
superDorifto
Not yet, but getting close...I think he takes his boards this summer. we spent most of the break hanging out/arguing about my set-up. He is 100% against breaking the motor in N/A, and kept throwing up lame what if scenarios to keep me form just installling stuff.
Getting pretty antsy to see some progress.
PapaSmurf2k3
Site Admin
I need to grab a beer with that guy.
Jmoore124
seems like everyone I know is like that. even people who don't have a clue ..."oh I would have put that here" or "you don't even need that" ...lol BACKSEAT DRIVERS!!
WDRacing
I love the "you don't need that" types. They pull everything off the intake and then have 1 thread a month about why their car doesn't idle.
BTL_nissan
Car: virgin 93 240sx s13
I really wish I would have seen this post before i bought this damn POS godspeed manifold. I'm guessing they havent changed anything in their design since you purchased.... They sent me the same spacers for the fuel rail that are no where close to fitting. Im not looking forward to making mine work. Although they do include the Iac valve adapter kit that is simply a plate that the iac bolts to with some hose barb fittings. This thing is such garbage, I hope its worth the money and time I am going to have to spend to make it work. I had no idea about the "velocity tubes" either. Now ill have to break mine apart clean all the rtv off of it and install :( im not looking forward to all this
superDorifto
The way I look at it, every piece on this car has needed some sort of cutting, welding, grinding, buffing, drilling, milling, painting, machining, soldering, and general tinkering to get it to fit right....
by the time I got to the manifold, I was already in for a pound, so I made it work. Thats really where the payoff is, "I MADE this s*** work."
Its not going to give me any more power, but I can look at it when the hood is up, and I'll know how many hours went into making this project come together.
Jmoore124
There is this, but also that the motor is SOO much easier to work on when you add an aftermarket intake manifold. Not only that, but the numerous ports on the stocker are a royal pita to plug and not blow off all the time. You can actually get to your heater hoses and whatnot, its amazing. I am in the process of building this.
And there is nothing wrong with the remote mount IACV. They work pretty well, you just need to find out a place to mount the damn thing.
WDRacing
I was going to DIY a manifold a long time ago. I was going to use a fire extinguisher as the surge tank. Would have worked pretty well imho.
Before I do anything like that these days I'll be going the V8 route. Having a V8 daily driver has spoiled me. Immediate torque is just...well fcuking awesome.
superDorifto
I was joking with my machinist about selling off all of my KA parts, and doing a VH or LS1 swap with the transmission kit I pieced together. I've never had anyone threaten my life with a socket wrench before.
He's almost as invested in this build as I am...also he already has a VH powered s14, and doesnt want to share - I think hes one of the only running examples in CT right now.
Oh well, at least I have some space to work now!!!!
Renting/trying to buy a house - got most of my stuff moved into the garage, still need to pick up the motor from Foster's
WDRacing
I can't wait to make our final move at the end of this year, we're going up to NW PA. Bout an hour N of Pittsburgh. I'm looking fwd to flying my Patriots flag in Steeler Nation!
Jmoore124
Pats ftw. You going to Carlisle WD? Dorifto I need you to start getting some serious work done. While I am unable to work on mine I need to live vicariously through your build thread.
WDRacing
Totally going to Carlisle dude, you?
PapaSmurf2k3
Site Admin
I feel like everyone in this thread (and Foster too, damnit) should be going to Carlisle.
...and I fly my pats flag in an area heavily dominated by saints fans. Everyone down here is more interested in freaking college ball though.
superDorifto
I would love to go to Carlisle, but
You guys are going to hate me...closing costs are a bit higher than anticipated and I need to seriously entertain liquidating parts of this build. Trying to put together the FS threads right now. I cant just do a blanket posting becasue NICO seperates out sub catagories.
Rest assured I am not selling the motor - but nearly everything else is up on the block...
WDRacing
Holy F dude! Really? That sucks serious balls. This thread has been on going for so long, I really wanted to see her finished.
superDorifto
I know. I'm trying to NOT sell the motor. I can pick up a shell on the cheap and build it nice and slow....especial with a proper garage.
All the overbuilt stuff is going to be up for grabs.
PapaSmurf2k3
Site Admin
I'm going to go ahead and VETO that idea.
PapaSmurf2k3
Site Admin
Can you just work more or transition to a mostly ramen diet?
WDRacing
PapaSmurf2k3 wrote:Can you just work more or transition to a mostly ramen diet?
PapaSmurf2k3 wrote:I'm going to go ahead and VETO that idea.
:rotfl :rotfl :rotfl :rotfl
superDorifto
Im already at 40% Coors Light...and PB sandwiches.
