Supercharging my KA24e
T-Bird
Car: 1992 Nissan Navara Ute
Hi I'm new to the forum and would like some help
I have a Navara ute with a KA24e in it and am in the process ofinstalling a SC14 supercharger to it I would like to know if I would have to change the ECU, injectors etc etc
Any help would be greatly appreciated
dickie
Car: Killer Turtle
by change the ecu, you mean swap a new one from a different vehicle in? no.
as for fuel system, i would say you should consider your needs and goals and talk to someone at a reputable tune shop with a dyno near you.
they will be able to tell you exactly how much fuel you need and how to get it.
T-Bird
With the ECU I mean should I change to an aftermarket one or will the original one be alrightAs with the fuel side of things the car will maunly be street driven I'll have a chat with the local gurus and se what they say
Cheers for your imput
neverlift
your gonna want to be safe and have extra fuel, rather than not enough. I'm about to boost 3psi on stock injectors and a fpr(at 55psi brings me close to 300cc/min),with walbro to ensure fuel is there. I have no doubts my 3~4 will be pushing stock injectors close to 100%duty cycle. If not I'm still not gonna trust it too much.
you can go stand alone, but price may be too high for you as it was for me. I'm not too sure on the navara's ecu stuff,but many have ran the stock sohc ecu boosted with success.... I even run my de on the stanza ecu(best sohc ecu from what I know), it is plenty versatile if that is a question or concern. Fuel as said already you want too much not too little. If you dont plan on major psi 370's seem to be the staple of most builds, ca18det is the motor your gonna want/need them from, but you could also go with aftermarket units those range from 370~1000+cc minute and cost more too.
Best of luck keep us posted.
T-Bird
Thanks neverlift for the info
I'm going to run about 10psi so the ca18det injectors sound like the go As for the ECU I'll get a stanza one as a standby and see how the stock Navara one goes
I'm putting the blower on a spare engine so I don't have to touch the engine in the ute I'll try and get it sorted before the engine goes in and then muck around with tuning after it's in
