Supercharging and Nitrous ideas
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
marksport
I got my mock-up motor last week and took the manifold off. I will be setting up my belts for the supercharger and didn't want to assemble my machined motor since I need have the rotating assembly balanced once I get the remaining parts back.
Supercharger on the left is the original 1.7L, the one beside it sitting on the manifold is the 2.2L and to the far right is the OEM manifold
Supercharger setup compared to the OEM manifold.
These show how the supercharger sits on top of the OEM lower manifold. It's not really any higher.
Supercharger with rear inlet mounted, same location as the factory throttle body.
Supercharger manifold showing the ports where the Laminova Liquid intercooler cores will slide in.
Plate style adapter from a Kenne Bell Ford V10 kit.
NOS NOSZle adapters installed into the OEM manifold.
NOS NOSZle installed with the Supercharger setup. Tight clearance on one of the fuel rail support mount.
VK45 Fuel pump mounting.
VK45 Intake manifold variations.
OK, here I go.....
some time I go, I had this little idea about seeing the possibility of a low boost simple supercharger kit for the VK45 using a plate style adapter. As you can see, the SC and the OEM setup are not much different in terms of physical size.
The plate adapter would be similar to the Kenne Bell shown above. You bolt the lower plate to the lower OEM manifold, and with the supercharger bolted to upper plate, you could now bolt the two plates together. The problem with the plate is that it would raise the supercharger by at least an inch and cannot be intercooled.
BUT....you could move the supercharger back to give it more clearance as the hood rises as it get to the firewall and you will need a longer extension drive.For intercooling, you can do methanol/alcohol/water/ect.
The manifold could also me machined down and the lower plate welded in, which would give you more room and the possibility of adding liquid intercooler cores.
I haven't decided how far I will go with this, but in case anyone is interested, I hope this is can give you some further ideas.
For the Nitrous, the NOS NOSZle kit is a very attractive looking setup as it fits between the intake manifold and the fuel injectors without requiring drilling and tapping. You do need to tap the fuel line off the rail. There is a billet adapter available for the G35/350Z that I think would work, but I have not confirmed this yet. This kit is a universal kit that will work on cars that use Bosch-style O-rings for the injectors such as our VK45.
This kit does fit under the supercharger but the bolt for the fuel rail mount is very close and need a low head bolt or capscrew to work properly. I haven't decided if I will run nitrous in my car yet.
When I was taking my mock-up motor apart, I noticed that the fuel rail did not have a return line, so I figured it was an M45 thing. Turns out that the fuel return line is a 2002 Q45. It just makes tuning a bit more difficult. If forum members can confirm what model and year your car is and if it has the return line or not, please let me know.
The last picture shows the variations of the manifolds and throttle body positions. This is important as it makes the plate adapter limited in what it will fit because of where the TB and MAF are located, unless they are willing to do some extra fabrication work.
I forgot to note that I have 2002 Q45, where as the mock-up motor came for a 2004 M45 that rolled over.
Raxephon
Car: '04 RX8...for the moment...
I hate you for having not one, but 2 whipples!
Looks good, keep it up.
Some of us only get to tinker with older eaton blowers.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Interesting, but I do wonder why you wouldn't want to nurse your baby on Tier 1 and get past teething problems before you introduce it to crack (NOX).
What about pistons, rings and the big end bearings?
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
anlasak wrote:I hate you for having not one, but 2 whipples!
Those are Kenne Bell s/c's. The Whipples have curved cases.
marksport
maxnix wrote:Interesting, but I do wonder why you wouldn't want to nurse your baby on Tier 1 and get past teething problems before you introduce it to crack (NOX).
What's Tier 1?
I haven't quite decided yet if I will run NOS. I thought I posted these before.
Low compression Venolia Pistons 0.020 oversized, block is machined to match with the deck o-ringed, Billet Pauter X-Beam connecting rods.
Kenne Bell used to sell Autorotors, where as Whipple used mainly Lysholm, but at one time or another did use the Autorotors. Each type was called to their respective importer rather than the manufacturer. Since both Lysholm and Autorotor are part of Opcon now, both styles are sold under the Lysholm name as Autorotor now concentrates on fuel cell technology. Whipple and Kenne Bell now make their own units after supply issues years ago during the Opcon acquisition.
Mettler
Car: HR31 GTS-8 coupe, VH41/45 Hybrid Transplant
Sick setup, was it cheap enough to get the decks o-ringed?
Orphan
Car: UZZ31 Soarer
Wow a VK build. I'm very keen to see it done.
tmorgan4
Car: 2000 Nissan Pathfinder
Looking forward to this one also. I'd love to do something similar with my VH eventually.
Return to “VH45DE / VK45DE / VK56DE Forum”
