savage25_sc wrote:coz ime thinking of the sc of the xterra..does it have the 3.3 or 3.5?thanks guys...one more thing coz ime planning to change my spark plug...what brand would you recommend?my qx4 is the 3.5L.tnx.
The Xterra had the VG33ER. Your QX has the VQ35DE, same engine found in the 350z, Maxima, Altima 3.5 and a TON of other nissan models. It's a much better engine, and it's got plenty of aftermarket options available for supercharging. As NISTECH said, any 350Z s/c should work with your engine. You *may* need a new hood to clear it depending on it's setup, but other than that, there should be no issues.
Check out these Stillen chargers for the Z. They're top-mounted roots-type, so you will need a new hood. But if you go centrifugal like PalmerWMD did on his, you should be fine for hood clearance.
