supercharger
elgarvo616
Car: 1995 240sx aka sweet thang
What ever happened to the few supercharger projects that were floating around. I know a few people started them but i dont see any follow thru. I would love to see this done/do it to my 240. mmm....torque
themadscientist
mm parasitic drag. The only time I would take a supercharger over a turbo would be for drifting. The more linear boost curve and speedy response would be favorable. Otherwise the supercharger takes back some power to generate power so two steps foward, one step back.
SeVa-S13
Car: '05 GTO 6spd
Just run a T25/T28 or a small T3. You'll get the same effect without the power loss: big power boost low down but suck arse in the upper RPMs. Atleast for roots...If you want a centrifugal, again, the same effect can be achieved easier and cheaper with a larger turbo.
elgarvo616
i kno i kno...turbos are more efficient that supers. but i would like to do something different. theres something about supercharged 4 bangers that i like.
dfw240_EE
Car: 1992 240SX
Just by the general characteristics the only supercharger that would make sense is a centrifugal unit (belt driven turbocharger). It's not as efficient as a turbo courtesy of the upgearing involved but it would come closer than anything else.
However, cost, weight, and complexity saving would be nearly non existant or negative (particularly higher cost) since turbochargers are so well worked out for this particular car and the only plumbing actually removed would be the exhaust piping and maybe some heat shielding (since the centrifugal is not being heated directly by the hotter-than-hades exhaust gasses). Intake piping, intercooler, and oil connections would all remain present.
That's my seat of the pants analysis. Check out Vortech for a start. http://www.vortechsuperchargers.com/
elgarvo616
ill have to look into it. but i dont have the resources of the tools to complete this sort of project. o well. i guess ill just have to jump on the sr bandwagon. ive heard its jdm tyte yo!!!1!!!oneone!!!
DanCouga
Car: 1997 Nissan 240sx
I thought Greg said someone was working on producing a kit. I'll see if I can find the link.
GEO
Car: 95 240sx KA-T
Guys.. PintoTech.com has resources and in the future months is going to develop a supercharger kit for the KADE.. goal HP is 260RWHP
elgarvo616
thanks for the link geo. ill have to keep my eye on that.
hybrid_flyer
Car: 95 240sx SE wrecked....89 240 coupe now
themadscientist wrote:mm parasitic drag. The only time I would take a supercharger over a turbo would be for drifting. The more linear boost curve and speedy response would be favorable. Otherwise the supercharger takes back some power to generate power so two steps foward, one step back.
ok I know I will take a beating for this one...but believe it or not turbochargers also remove power from the vehicle before adding it. I had an engineer explain it to me and the short version is, because the exhaust gas isnt traveling straight through in one direction it slows down, hence removing power.
240crawler
Car: 1991 240sx
I am not a automotive engineer, but I personally favor supercharging. I bought a 97 Integra with B18c5 that had an Edelbrock complete turbo kit. I had ZERO power down low, with a fairly linear powerband to the top. It had a loss of power before VTEC, but that is due a butt dyno.Drove a 96 later for 2 months with supercharger (Jackson Racing?). Loved the power, was very smooth from 1500 to redline. Had as much on top as the small turbo in Edelbrock kit, but dyno on my browneye said 3 times the low end torque. Just my opinion on 2 very un-Nissan cars.
themadscientist
hybrid_flyer wrote:ok I know I will take a beating for this one...but believe it or not turbochargers also remove power from the vehicle before adding it. I had an engineer explain it to me and the short version is, because the exhaust gas isnt traveling straight through in one direction it slows down, hence removing power.
Nobody should beat you up because you are right The resistance imparted by having the turbo in the exhaust tract is far less that the belt of the supercharger though.
rexhunta
Car: '95 Mitsubishi RVR ( 4G63T and AWD thanks !)
MY10 Forester X LE
Supercharged CA powaaaaaaaaaaaaaaaaaaaaaaaaaaaa
hannibal
Car: Red Line to Glenmont
Crazy Aussies
Thats the first time Ive seen a non factory Roots charger that didnt use a new (modified) intake manifold.
DanCouga
Anyone know what the prices are like on Ogura superchargers and if there is a US distributor?
s13 240
Car: 1990 Nissan 240sx
elgarvo616
whoa whoa whoa...is that what i think it is? i need more details
hazw8st
Superchargers are wonderful for 4 stroke Miller-cycle engines. Many people see a supercharger on a Mazda Miller-cycle 4 banger and think...Gee, I can do that! In fact, a turbocharger is exhaust driven, which operates off of the wasted exhaust energy which allows the very inefficient 4 stroke gas engine to recover some of the ill wasted heat energy. The parasitic drag of the supercharger is a setback for that type of forced induction. In principal a Jackson supercharger equals 80-100 horses of bolt on hp/torque, when you offset the hp/torque figures by subtracting the 35-50 hp that is needed to power the supercharger, the gains all of the sudden are not that amazing. Parasitic drag is a bummer. Especially when the 35-50 hp a supercharger demands come directly off the crank. Superchargers are easier to install, are less problematic, are easier to service, are easier to tune. However, nothing beats a turbocharged induction unit on added brute horsepower. A turbo is problematic in general, especially when the turbo is a hybrid and it's not matched to the particular application and powerband. There are more variables to consider with a turbocharger than with a supercharger. All a supercharger really is, is a belt driven turbo.
Let the boys play with superchargers and the men play with turbos.
TheOne
Car: 93 240sx FB
yeah, the "boys" drive supercharged over 6000hp dragsters.......
DanCouga
hazw8st wrote: All a supercharger really is, is a belt driven turbo.
Actually, it's the other way around. A turbocharger is just a supercharger that is powered by exhaust.
elgarvo616
everyone is tellin me that turbos are more efficient, more power, etc. im not looking to make 400rwhp. im only looking for like 250. this is my daily driver all year and i need to commute to school 40 mins away. i just want something that has some balls so i can enjoy some "spirited" driving.
themadscientist
rexhunta wrote:Supercharged CA powaaaaaaaaaaaaaaaaaaaaaaaaaaaa
It's performance was disappointing, they gave up on ittttttttttttttt. Option or one of the other magazines did that car, not the Aussies. A supercharged RB was similarly a letdown.
themadscientist
elgarvo616 wrote:everyone is tellin me that turbos are more efficient, more power, etc. im not looking to make 400rwhp. im only looking for like 250. this is my daily driver all year and i need to commute to school 40 mins away. i just want something that has some balls so i can enjoy some "spirited" driving.
If all you want is 250hp, the supercharger will do that. You will need to find a first-gen MR2 supercharger and yank the blower. It is the same type you see in the Blitz kits. I suggest stepping up to at least 444 injectors and an SAFC, nice FMIC and overdrive the blower a bit. I have driven an MR2 with the HKS overdrive pulley on it and it's a lil screamer. Go for it!
hazw8st
themadscientist wrote:If all you want is 250hp, the supercharger will do that. You will need to find a first-gen MR2 supercharger and yank the blower. It is the same type you see in the Blitz kits. I suggest stepping up to at least 444 injectors and an SAFC, nice FMIC and overdrive the blower a bit. I have driven an MR2 with the HKS overdrive pulley on it and it's a lil screamer. Go for it!
themadscientist: I second that! The 1st generation Toyota MR2 supercharger is good for over 250 with a FMIC.
Also 6000hp is only possible with alchohol dragsters with $250K engines. Lets limit the posibilities to what we can afford.
If 6000hp is imaginable to you, take another look at your pocketbook.
Modified by hazw8st at 3:19 PM 9/14/2005
hybrid_flyer
well my employer has a guy that designs and builds custom turbos and blowers. He was able build one for my bosses porsche boxster. So I will see what he says and get back to everybody
rexhunta
MY10 Forester X LE
themadscientist wrote:It's performance was disappointing, they gave up on ittttttttttttttt. Option or one of the other magazines did that car, not the Aussies. A supercharged RB was similarly a letdown.
Correct !!
On another note, G-Speed in my home town have made a turbo/supercharged Subaru Leone with the engine being from a RS Liberty, with a toyota s/c and a t3.. not completely running yet.
hazw8st
Yeah supercharger at low rpms and turbocharger for high rpms.....
dfw240_EE
Car: 1992 240SX
As a side note I understand HKS made such a twin charger unit for the old Mk1 MR2. Not any more of course. No love for the guys who like the old cars
Juujai
hazw8st wrote:Yeah supercharger at low rpms and turbocharger for high rpms.....
not really. there are smaller superchargers for lower end and bigger ones for higher end. and there are smaller turbos like the t25s and t28s for lower ends and bigger ones like the gt3037s for higher end.
they're both pretty efficient and i'm pretty sure we can see some big numbers in the powerband with either.
elgarvo616
ill have to look into this. im assuming it would be ALOT of custom work, right?
