Supercharger mockup
marksport
After waiting for a custom pulleys.....and still waiting, I decided to mock up supercharger and start assembling process.
Front of the engine
Back of the engine
Side
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Nice bracket and serpentine belt routing.
Are you going for an oil cooler and larger capacity radiator also?
marksport
maxnix wrote:Nice bracket and serpentine belt routing.
No room for a thicker radiator as there is the battery and airbox right behind it.
There is going to be B&M Hi-Tek oil coolers on each side, one for the engine and the other for the transmission.
unknown007
Car: White 1993 Q45 (G50)
this is the VH41?
marksport
unknown007 wrote:this is the VH41?
Nope, VK45.
unknown007
marksport wrote:
Nope, VK45.
Same thing.Just kidding!!!Nice can't wait to see it run.
marksport
Close, VH45 initially stronger as it has slightly thicker castings and the girdle, tho that can be brought over to the VK.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
What purpose does that vertical bracket above #1 exhasut port serve?
SanCarlosQ45
Car: 1994 Q45 144,000
2013 Nissan Xterra Pro-4x
1967 MGB GT Special
If it is the same thing I saw it looks like it is a mount for pulling the engine as there is another on the other side.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
SanCarlosQ45 wrote:If it is the same thing I saw it looks like it is a mount for pulling the engine as there is another on the other side.
Ah, on #8! You must be correct.
marksport
Yes, they are called engine slingers that you buy from the dealer or normally come with a longblock.
marksport
There is a VH45 in the background, pic #5.
MR. Q
U have many blocks!
CT240sx
is that belt custom made or pulled from another car?
apossiblehybrid
Car: 1994 Q45
is it going into the civic?
marksport
CT240sx wrote:is that belt custom made or pulled from another car?
Belt is just a generic 6-rib belt. Bracket was made for this setup.
