supercharged sounding 240sx
mordakibojangles
Car: 89 240sx
hey everyone i own a 89 240sx with the ka24e. A couple of weeks ago my automatic transmission started slipping real bad in 1st gear. At the same sime it had this supercharging sound above about 2000rpm. I figured it was all transmission related.... So perfect time for a 5 speed swap. Did the swap with great success but yet i still have the supercharger sound above 2000rpm. Just so everyone knows ive searched all over the internet to find out what the problem is and i am having no luck. Also i deleted the power steering as well as the ac. There is only one belt left on the car which goes from the fan clutch which i just replaced and the alternator. All help would be greatly aprreciated.
Fastazz240
Car: 1995 Nissan 240SX
93 Nissan Vert
95 vHardbody 4X4
maybee water pump?? does the sound increase with RPM's or stay constant and any idea specifically where said sound is coming from a general location would be a little easier
mordakibojangles
Car: 89 240sx
the sound increses with rpm and it is coming from the front of the car
Fastazz240
93 Nissan Vert
95 vHardbody 4X4
did you change the waterpump ? possibly the blade contacting something but i would bet it has somethign to do with your pullys
ekaio8o8
Car: 91 240sx Hatch
I had this problem months ago it might just be that one belt.
when i was driving trying to find the sound, my alternator belt broke and got stuck on all my other pulleys, i replaced it and it was gone
BentCrank
Car: 1998 Nissan 240sx KA24DE
Happened to me last month, oil in the alternator.
AntonioG
Car: 91 240sx
I believe this thread just helped me out. Because my ka24de has that same sound. So, thanks for inadvertently helping me out too!
solallein
Car: 1995 240sx
Maybe a vacuum leak? Does it sound like its mostly around the intake manifold? How loud is it?
NightWalker86
Car: 1996 Nissan 240SX
An easy way to test the accessories would be to remove the one belt you have and go for a VERY quick blast down the road making sure to keep an eye on the temp gauge. If the sound is gone then you can narrow it down to the Alt. or water pump more than likely. Good luck.
