benemorius »
https://forums.nicoclub.com/benemorius-u17066.html
Tue Nov 02, 2004 4:55 pm
If it's in good condition, your 240 can probably already beat many of the lawnmowers running around town. Not all of them, of course, but so many are 70% show and 30% fartpipe, leaving them with not much more than they had stock.
Probably everyone here will be shoving you down the turbo road, and there's good reason for that. Check out the Ka-T section. You'll find everything you need to know there.
There's nothing wrong with hitting the track with a stock car. It will give you an idea of what it's like, as well as let you know what kind of condition your car is in performance-wise. Give us some more info on your car (year/model, miles, mods...)and someone can probably tell you about what your 1/4 time should be if your engine is in good shape. If you're running a bit behind, you'll know you need to start with a slightly deeper tune-up than the one you should have already performed the day you got your used vehicle.
