evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed Aug 02, 2006 5:36 pm
It might fit, it's basically a single cam version of the same engine as the Z but then you get less power, the SC's were only about 200 hp and the stock Z32 N/A was 220 hp, the TT is 300HP and for about a grans you can due the "Stage 3" on the TT (intake, exhaust, ECU boost jets) and get to around 400 hp, these are of course crank numbers but a few cas have manages to hit 400 whp with stock turbo's, if it's power your after stick to the TT swap, no need to reinvent the wheel
