itsa300zx wrote:I'm not "NolimitZ32" but IMO,
Stock TT pistons, use TT oil squirters
After market TT pistons, use NA oil squiters
True, but if you are going through all that work, you might as well get some nice forged pistons instead of the stock TT pistons which are the weakest link on the DETT, a set of Wisecos will run you around $600 with wrist pins and rings, will give you a wider safety margin when making extra power and REQUIRE N/A OIL SQUIRTERS just as you said. On top of this if you are going twith stock TT pistons than the TT oil Squirters are no huge expendature. Also NA squirters can be converted to TT and TT to NA, I am running TT squirters converted to "NA" since i'm running CP pistons. Conversion takes carefully changing the angle of the bend of the tube, granted it is easier to go from TT to NA than from NA to TT since the TTs have a speced angle of spray and the NAs are just a 90* bend.
If any of you guys are serious, I have a set of 6 TT Pistons complete with wrist pins and rods that I can give, free of charge (just pay the shipping) to the right individual. Here is the deal, you have to actually be using them for a build, you will need over-sized rings and you may be a slight bit out of spec as I think 4 of the 6 are grade 1 so make sure you have grade 1 bores first. Also you gotta understand that I am not in the US right now and will be asking my dad to dig through a bunch of my stuff that's in storage to get these so don't ask unless you really do need them out of respect for my time and my dad's.
