Supercharged 2002 Q45 update
marksport
Well, as most of you know, my 2002 Q45 has the Keuylian supercharger kit on it. Last month, I lent it to a friend of mine who went to a honda car meet in Seattle. He street raced several cars. Good news is that he beat most of them including turbo Civics and Integra. He also raced the new M6, and it could barely pull away from the Q45. The bad news is that he blew the supercharger. I have now decided to pull the supercharger out.
I will be building a low compression motor in the next few months and a high performance transmission, as well as rebuilding the supercharger.
Ozzie
Car: '90 Nissan 300ZX twin turbo - 2 seater
'99 Mitsubishi Legnum VR-4 Type-S twin turbo
'71 TA22 Toyota Celica (flat light)
'06 MK5 Golf tdi
and some motorbikes too
Sounds like you are using your turn of bad luck to make all the right improvements.Keep us updated and maybe post some video when she is back on the road and all sorted out.
COOL!!!! I've always wondered about these supercharged Qs. I've never met anyone online who actually had one, as they all were on dealer lots or on eBay for some reason.
superuber
Hey, when you get her fixed up lend it to me and I can race Wes and beat him! FRIEND!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Another one bites the dust.
Doing the low compression motor should be a great starting point for a more robust engine.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
So the VK is holding up fine, but the supercharger went to pots? Sounds good, you know its good when everything but the motor is breaking!!
Still a stock transmission too?
How much boost are you running. Id think if you keep it under 10lbs you dont need to lower compression...?
NewNismo
"So the VK is holding up fine, but the supercharger went to pots? Sounds good, you know its good when everything but the motor is breaking!!"
No kidding... Never head of someone blowing the S/C before the motor.
Q_SHIP
Car: 1999 Q45T with a billion miles.
What exactly let go in the blower?
marksport
Not too sure, but I think the bearing in the blower got overheated since it uses the engine oil supply. The supercharger rebuilders I spoke to usually fill and cap off the oil reservoir as the engine oil can get too hot and damage some components that then result in the failure of the bearings. I was running 8 psi on the blower and plan to run 15 psi once the compression is lowered. The transmission is still stock, there is some slip but we installed this system with 103,000 miles on the odometer.
elwesso
2007 BMW M Coupe
superuber wrote:Hey, when you get her fixed up lend it to me and I can race Wes and beat him! FRIEND!
In a straight line youll get me, but Ill take you any day in the turns!!!
