superbraut »
https://forums.nicoclub.com/superbraut-u121303.html
Sun Jan 25, 2009 1:47 pm
Here is what i have so far for my 5 speed swap.
As for the clutch pedal assembly this is all i have. I repainted the bracket, but the pedal was pretty gouged out by the spring so im thinking of just buying a pedal assembly from courtesy. The pedal assembly would be part # 46540 right?
The driveshaft i bought isnt in such great shape and the center bearing is warped. You cant really see it but its egg shaped. that means i also need to buy a new center bearing right???
Heres close ups of the transmission.
messed up brackets
messed up sensors...does anyone know which ones these are?
Speed sensor
Front of the transmission
Should i release the bearing retainer?
And the pivot fork?
Im waiting on other parts.
okay the parts i need left are the:
shifter, shift knob, hardlines, flywheel, radio trim, transmission/engine dust cover,bell housing bolts, flywheel bolts, pressure plate bolts, ecu, new pivot ball, transmission oil seal, transmission/driveshaft dust cover
As for the hardlines, i already have a nismo clutch line that replaces the soft line, but for the hardlines do i just need the hardline by itself or do i need the entire assembly as shown here. I read people saying i also need the bracket? What part is that?
Well im almost complete on buying my parts, so please any suggestions would help.
