nmgoodthing »
https://forums.nicoclub.com/nmgoodthing-u42633.html
Tue Feb 05, 2008 5:11 pm
I took me 1/2 hour to do myself.
I didn't have any poppers to deal with. I used a floor jack and jacked up one side of the car. There were about 6 bolts that needed to be removed from the plastic part underneath then you can access the actual fog light. remove the 2 nuts holding the fog light on and unplug the wires and you can push the whole housing out toward the front. From there it's easy replacing the bulb.
Once you have the housing out figure out a way to clean up that moisture. clean shop rags or something.
Personally I don't waste money on the bulbs anymore. OEM cheapos have lasted longer then anything else I have put in there. I've had Silverstars, PIAA's, Raybrigs, Hella, Lumincs, etc. They all didn't last long. These fogs are purely cosmetic I have a feeling. No matter what you put in there, there isn't much light output compared to the HIDs.
I did like the look of the Lumincs Yellow H3's I had, but those were 30 bucks a pair, you will pay the same for silverstars, and if your trying to match the HID's they don't even come close.
