Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Sat May 13, 2006 6:16 am
Well, I have already checked piston travel and piston height is the same among them. In any event I do need a new cam gear, and so I will reset cam timing today anyway. No offense, but I would love to tell you all that you are wrong, but I probably will not. Next step I guess will be a leak down test. I understand your point in finding the low compression issue, but the way I see it, the engine should not be able to make more than stock compression with stock parts, it's just too weird. I don't know. I have been testing and testing with this damn thing. What's one more day? I will let you know if anything changes.
BTW, will a failed ECU throw fluke codes without throwing a faulty ECU code. I was doing electrical diagnosis yesterday since I had 4 codes, and went through the whole diagnostic procedure and them got to the end and everything checked out. The ECU is not bolted down, could a bad ground cause that. I am beginning to loathe this car.
