Super Weak Gas Milage
prdquik
Car: S13
My car gets like 14-17 mpg . The motor is brand new with like 3,000 miles on it. It went for smog testing in november, and passed with flying colors. What could it be? I need this fixed already.
EDIT:KA24DE,Its manual, I drive about 70% streets and 30% highways, And the motors stock.
Modified by prdquik at 5:11 PM 1/3/2010
Modified by prdquik at 5:19 PM 1/3/2010
TheRealNap0le0n
Car: 1998 q45
transmission Type?
Typical Driving Conditions?
Mods?
btw my car just clocked off 29mpg
prdquik
Car: S13
TheRealNap0le0n wrote:transmission Type?
Mods?
Its Manual
About 70% streets, 30% highway
And motors stock.
I wish I was pulling 29mpg
danield319
Car: 240sx
prdquik wrote:. The motor is brand new with like 3,000 miles on it.
what kind of motor?
locoluna825
Car: 90 240sx coupe
what kind of motor? ka? DE? SOHC?
prdquik
Car: S13
locoluna825 wrote:what kind of motor? ka? DE? SOHC?
danield319 wrote:what kind of motor?
KA24DE
E7-S14
Car: ess 14 foo!
240s never got 29mpg
you should expect 17-19 city and 24-25 highway.
all depending on HOW YOU DRIVE though.
prdquik
Car: S13
E7-S14 wrote:240s never got 29mpg
I get like 170~200 miles to the tank when i'm reading about people that get 300
prdquik
Car: S13
And I read all these threads about similar issues and everyone seems to say replace the o2 sensor
But if it was the o2 sensor it wouldn't have passed smog in november would it?
TheRealNap0le0n
Car: 1998 q45
my motor has 2'000 miles on it. s14 KA24DE manual transmission, stock intake, stock exhaust aside for a muffler, egr removed, swirl valve disabled, charcoal canister removed
on my trip home from miami i got 29mpg dont believe me... but my wallet does
locoluna825
Car: 90 240sx coupe
i will get 29 and sometimes even 30 on the freeway. but i only get 18 or less in the city depending on how i treat it.
chaosli
Car: 89 nissan 240sx coupe FTW
99 mazda miata
93 bmw 325i RIP
i got 9 highway 4-5 local single cam turbo no tune
befor turbo i got over 300miles a tank always shifting befor 2700rpm
E7-S14
Car: ess 14 foo!
chaosli wrote:i got 9 highway 4-5 local single cam turbo no tune
wow.. might as well just LS1'd it.you'd get better gas mileage and be just as fast...
dana541
Car: 1990 240sx
you have a serious problem if you are getting that kind of mileage.turbo charging makes your engine run more efficiently.at low boost cruising you should get better mileage than before.
maybe you have a giant hole in your gas tank
PEZi
i don't have a KA... but i have the predecessor to the SOHC one... same bore and stroke... my truck weighs 2,000 lbs and after the project i'm currently doing i'll be looking at 10 mpg highway
as long as you're not fouling spark plugs consider yourself ok
xX RB Xx
Car: SE3P, FC3S, FC3C.
damn i used to get 30 mpg in my de 14.
Nonsense
Car: s14 zenki
I got about 360 to a tank in my Auto s14
prdquik
Car: S13
Ok anyone have any ideas as to why my gas mileage is so Sh***y?
LayNLow240
Car: 92 240 coupe
s*** I got like 32mpg on my trip from nashville to memphis. When I had it I got like 24 city driving. Check your plugs, gap, wires, cap, rotor, fuel filter, and o2 sensor if they arent new. Otherwise check your fuel lines for cracks and or weird discolorations. Also check your ground and power wires, and make sure all of your sensors are plugged in and secure.
dana541
Car: 1990 240sx
check your oil for fuel.maybe an injector problem.
youngun21a
Car: 240sx 1993 Automatic
I get 29mpg..sometimes i make it to 31..but rarely...I haveCP Pistons Comp_9.0:1,Supertech Valves,stage two Crower Cams..and a cheaps air intake with a aem filter...
