evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed Jun 13, 2007 6:22 am
CHTS= Cylinder Head Temp Sensor, it's either at the base of the head on the passanger side between I believe spark plugs #4&5 (might be 5&6 but I'm too lazy to go look, or on earlier cars it was located in the lower thermostat housing, it'll be the connector with 2 wires
the afm tells the pump to come on and stay on, if the afm gets stuck it only primes the fuel lines then shuts the pump off, might be kinda dumb but thats how the bosch L-jetronic injection system on the z's was made,so you'd have adequate fuel pressure for startup then when it ran out it would die, and bad afm or just bad afm connector contacts have been known to casue all kinds of wierrd problems
as for the injectors, they do not use a ground, theyu use a square wave disconnect signal, basically constant hot on one side and disconecting hot on the other side
as wierd as this p[roblem seems to be could also be a bad ECU, is your car turbo or n/a?
