SUPER SQUEAKY annoying brake pedal !!!
gian52
Car: 240sx s14 95
i just replaced my brake booster because it went bad now my brakes work perfect but only one thing is bothering me when i press the pedal down it does this annoying squeaking noise like if your rubbing a chalk against a blackboard but i sprayed the pin and the where the pedal connects to the booster with wd-40 still not luck. Help me out please my ears are bleeding !
Did you lubricate the bushing where the rod goes through the firewall?
gian52
Car: 240sx s14 95
No i did not. The one that connects to the master cylinder correct ?
Yes. Lubricate the rubber grommet where the rod slides through it.
Amays U G37S
Car: shoes
I think one of your caliper's are stuck
But that's just me
95zenki man
Amays U G37S wrote:I think one of your caliper's are stuck
But that's just me
yup i had the same prob. my right rear was stuck and it would squeak a bit somtimes... its really not hard to check and see if you have a stuck caliper.
gian52
Car: 240sx s14 95
But that's just me
i dont think it would be my caliper because it didnt do it before i replaced my booster and my brakes seem to be working just fine.
gian52
Car: 240sx s14 95
AZhitman wrote:Yes. Lubricate the rubber grommet where the rod slides through it.
lub the rubber part right behind the brake pedal or do i need to take off the MC and lub that rod up ?
No, don't take off the MC.
Find where the rod goes through the firewall. I bet that's where it's squeaking. You're gonna have to crawl down in the floorboard and find it. :)
costa_rican13
Car: 1993 s13 coupe
my clutch pedal does the same... :(
LoserCard
Car: Forest Green 1993 240SX SE Fastback
Yeah, don't mean to thread jack but any info on how to stop the clutch pedal squeaking? I have a new master cylinder and used pedal. Did I forget to lube something?
Guys - finding squeaks is as simple as crawling around and moving things until you locate the source.
Usually, it's a pivot point, but in his case, it sounds like the metal rod squeaking against something at the firewall...
King Ranzo
Car: 15 Ford Focus ST
It could be the grommet behind the pedal. I had the same problem on my old forty. I changed the grommet and the problem went away.
gian52
Car: 240sx s14 95
lol well i jus sprayed wd 40 on everything couple days later it just stop squeaking thanks guys. yea my clutch pedal does it also but i jus think cause its super old
Razi
Car: Moo
The clutch fork probably squeaks at the pivot ball and the slave cylinder.
I lubed mine when I did my clutch swap and it stopped squeaking.
