Sure - I had similar symptom, but the sticking tapping noise would only occur at over 4000 rpm under load (in drive).munkmunk wrote:Leased new EX35, which has really annoying mystery engine noise. Tech's can't hear it. I will skip the usual whining, and just say that if Infiniti fails to resolve the issue, I will return it under lemon law provisions.
Here are the facts: - Cyclical, mechanical engine noise (almost like a Diesel, or sticky lifter) heard at slow speeds (0-50 MPH), between 1k-4k RPM, under engine strain (from a stop, up a hill, etc). - Unpredictable. Occurs in hot and cold conditions, both weather and engine. - 92 Octane fuel always used, including different brands in different cities. - Detected at ~275 miles. Still present at ~1,200 miles. - Cannot be heard when increasing RPM's in Neutral, or under engine breaking. Only under vehicle movement. - Sound not present on another new EX35 with 1 mile on odometer.
Anyone have any bright ideas? Great car, hate to return it, but this is unbearable.
sounds like they're trying every shortcut before needing to do anything that requires time/labor. demand that this be taken care of, or if they prefer, that you'll just contact Infiniti HQ directly because the vehicle was leased and you expect the customer service that is supposed to be representative of a luxury brand such as infinitimunkmunk wrote:The dealer now assures me that this is a timing issue. He recommended that I try fuel additives.
Adding an octane booster did smooth out the noise, but it is still there, and I can't imaging driving this thing for another 30k-50k with it.
What sort of issues could be plagueing the engine timing?
I am having the local dealer check my car out. When I talked to them about the strange noise I had been hearing and the heater core tech bulletin they said they have never had an EX with this issue before. My 08 was part of the first batch from japan.SteveTheTech wrote:Octane boost is not a valid fix. It just isn't an answer.
The heater core noise threw me for a wicked loop when I first heard it. I started pulling the dash board apart before I was actually able to realize that is the sound from the heater core. This is not to say this is munkmunks noise.
It could be. Retarding the timing was one of our little tricks for dealing with octane variation and some case by case issues. The only time I have personally ever done this was on an I35 and that was only 3*. Some of the G guys swear by adjusting the timing for power but I personally think the computer having final say is more likely to be right than anything I can do for it. If the battery goes dead or the computer was reprogrammed the EXT learned position might be off as well as the Closed Throttle, and Idle Volume.munkmunk wrote:They retarded the timing as much as possible, within factory spec, which has almost eliminated the noise. Could the Exhaust Timing still be an issue? Could it be the issue if retarding engine timing resulted in improvement?
