slim_240 »
https://forums.nicoclub.com/slim-240-u129502.html
Sat Dec 19, 2009 11:38 pm
i have a stock s13 blacktop with a t25 with SS lines. it only whines when i'm a little hard on the throttle. but if i'm easy on it, you can hear it spool up like normal.
it still builds up a strong 9psi and kicks in like it should. i checked shaft play today and everything checks out perfect. spins freely with no bent fins and does not make contact with the side walls. i get no black/white smoke after start up and all the SS lines are nice and tight.
the only thing i can think of is when i bought the SS lines, the return line was not like the t25 with the banjo fitting, it was just a regular screw on fitting. dunno if it was made for a t28 or something and has a restriction on the fitting and causing oil starvation to the turbo. they're TAKA lines if you were wondering.
i'll see if i can take a video so you guys can see what i'm talking about.
thanks!!
