This is good history so you guys now where your motors came from. The last sentence in the first paragraph is classic, and last sentence in last paragraph is classic as well. But I will let you read, hopefully you will interpret it like I did. If you go to the site below it has info on all ca engines.
http://en.wikipedia.org/wiki/Nissan_CA_engine
The CA engine is a 1.6 L to 2.0 L Inline-4 piston engine from Nissan designed for a variety of small Nissan vehicles. It is an iron block, aluminum head design with a timing belt. Earlier versions featured SOHC and 8 valves for mid-range power. Later versions featured DOHC with 16 valves for increased high RPM efficiency and smoother power delivery. It is effectively a Nissan RB block with two less cylinders. Components from valves to lifters, as well as bearings, are similar if not identical to the RB and VG series engines. The motor was expensive to produce being cast iron, so it was replaced in 1991 by the SR series as the primary Nissan 4 cylinder engine.
The CA series engine was the workhorse of the 1980s and was a bulletproof little engine. The power ratings were heavily choked by emissions regulations and Nissan's desire for high gas mileage. The CA design ended in 1990 with the ultimate CA engine, the CA18DET.
CA18DETThe 1.8 L CA18DET was the last version of the CA engine to be released. It produces 169 hp (124 kW) and 168 ft.lbf (228 Nm). It received a brand new DOHC aluminum head with 16 valves. The turbocharger was also upgraded to a Garrett T25 (.60 A/R) unit for increased flow capacity, and as such, was fitted with an intercooler to help volumetric efficiency. Fuel was delivered via Multiport Fuel Injection. Bore is 83.5mm, and stroke is 83mm. This near square design, coupled with the head design, allows CA18DETs to spin well beyond 7,000RPMs, even in stock trim. The CA18DET is a robust built engine considering that many people have produced up to 600hp with modification.
It was used in the following vehicles:
1987-1988 Nissan Silvia S12 GT-X(International market) 1989-1990 Nissan Silvia/180SX S13 (International market) 1989 Nissan Bluebird SSS Atessa (International market) Nissan Exa Turbo (Australia, non-intercooled)
There were 2 versions of the CA18DET availible, yet only one was produced for Japan. The Australian and Asian CA18DETs received 6 port (low port) heads, with butterfly actuated auxiliary ports in the lower intake manifold which corresponded with 6 ports in the head. Below ~3800RPMs, one set (3 ports) of long, narrow ports would be open, accelerating the intake charge to the cylinder. This allowed for quick spool and good low end tractibility. At the 3800RPM change over, not only would the ECCS shift into batch fire (as opposed to sequential) fuel injection, but it also opened the second set of short, wide ports which assisted in high RPM flow. This motor is knows for stronger torque characteristics, as well as faster spool at lower RPMs. However, due to displacement-based taxation laws in Europe, the CA18DET was sold as an option in the 200SX (Euro model) of the S13 chassis until its end in 1996. The later motors received the 4 port (high port) head and intake manifold, as well as revised ECCS ("Electronic Concentrated Control System") parameters. Power was not increased, but high RPM flow was indeed improved, making the 4 port CA18DET the most desirable of the late generation Nissan turbo 4s. Due to superior head design (cam on bucket, as opposed to the flawed complex and heavy rocker arm actuation of later motors like the SR and QR series), many enthusists consider the CA18DET to be the best engine platform since the FJ20/E/T that powered the legendary DR30 Skyline DOHC-RS.
