eman2222 wrote: ↑Sun Jan 09, 2022 7:28 am
Same issue for me. 21 SL premium. It continues to blow hot long AFTER it reaches the set temperature. I am an “auto” guy. Every car I’ve owned for the last 30 years has the auto climate control feature. I get into friends cars and put it on auto. Maybe it’s the thermostat or where it’s placed in the car. It blows hot all the way down to a set temp of 61 degrees long after the temperature in the cabin had been warmed to well above 70+ degrees (at least it feels that way to me). Lower it to 60/Lonand it blows ice cold. There’s nothing in between. I will say that the problem seems to resolve itself after driving the car for an extended period of time. But not until the temp in the cabin is at least 10 degrees warmer than what you’ve set it to be.
I'm finding on longer trips it blows less hot on 61. I had to turn it up to 63 because it was getting too cool in the cabin.
When it's 20F outside it blasts heat for a long time.
When 44F outside, it blasts much shorter and 61 is less hot. I say less hot because 61 is not cool like other cars in the winter.
It's hot on short trips and much better on 30 min trips.
It is poorly designed (and I'm afraid "working normally") as I have owned over 65 cars and I've never had to run the temp on the minimum or feel the need to crack a window in the dead of winter. I'm wondering why none of the testers picked up on this during development.
I was going to have it checked last week but canceled since it does seem to be responding better to inputs. I have a case# with Nissan and will have it looked at after I get more experience.
