super high idle problem
sileightyB
Car: 1990 nissan 240sx hatch
my car has an egr delete and trying to figure out whats going on with it
the iacv should work, maf was cleaned, idles steady but at 2k
not sure what it coudl possibly be, missing all egr and all things are plugged
pretty sure the tps is good too
anybody shead some light onto this thanks
s13_chris
Car: 90 240sx Hatch
timing?
Gabes13
Car: rb20det s13
sileightyB wrote:pretty sure the tps is good too
check it again.
-the out put voltage should be 0.45V (+/- 0.05V)*If not, adjust so it is.**If you can't get it into spec, TPS is bad.
-Unplug tps and adjust the screw on the IAA*If nothing happens, TPS or circuit is no good.
Gcustoms
Car: 1992 240sx LE
cold where you are?i run advance timing (big surprise)and when its cold out it idles a 1900 until it warms up then steadily makes its way down to 900rpm
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
A bad coolant temp sensor will cause this.
vancouverbc
Car: 1991 240sx
Isolate where all the air is coming from. Block the hose entering the iacv at the iacv with pliers and rag. Block the hose coming off the plastic black plenum that leads to iacv and air reg to see if air reg is open. block all the air at filter to check for leaks.
block the air going through throttle. do this systematically one at a time to isolate where the air is coming from. ive never done this but seems sensible.
ie too much air through the iacv could be broken spring or too much air through throttle could be tps or throttle plate set wrong etc
sileightyB
timing is dead on.
I can't get a reading from my tps for some reason but, it came off my friends car and it worked fine. I think it might be the plug that comes off the engine harness cause it's looking pretty frayed.
If i had a bad coolent temp sensor wouldn't i not be able to tell how hot and cold my engine is running? cause that works fine.
l3thalyendl3ss
Car: 91 180sx ka-de na
Sounds stupid but check the pedal assembly and set points on the tb and make sure the throttle cable isnt binding or anything like that. also check code on ecu for a faulty injectors sometimes a code light wont be thrown but the problem still proceeds I dunno just my two thoughts
vancouverbc
Car: 1991 240sx
sileightyB wrote:timing is dead on.
Is the tps adjusted? It has to be adjusted if you have put a new one on. ie loosen two bolts and rotate until it reads .45 v. Computer reset and idle reset.
back probe it while it is connected
sileightyB
will adjusting the tps really change my idle from 1500 to 800? I still need to adjust it but i dont think it will change it that much. I just replaced the gasket for the iacv and it drop from 2000 to 1500 and its closed all the way. Ive taken my intake mani off twice to double check and make sure everything was pluged up right and its fine. any other ideas guys?
blueballa
Car: 97 kouki
O2 sensor???
vancouverbc
Car: 1991 240sx
sileightyB wrote:will adjusting the tps really change my idle from 1500 to 800? I still need to adjust it but i dont think it will change it that much. I just replaced the gasket for the iacv and it drop from 2000 to 1500 and its closed all the way. Ive taken my intake mani off twice to double check and make sure everything was pluged up right and its fine. any other ideas guys?
of course. the wrong tps setting will screw things up.
maj Andres
Car: Zenki, '95 Model, w/ S14SR20DET
I got kinda the same problem....When i start my car it idles at 2k then after about 2 min it drops to 1.5k then after 30-45 secs drops to 1k and holds. It runs fine though. it's an s14 with an s14 sr20. My guess is the turbo is "warming up"
