huguetguy »
https://forums.nicoclub.com/huguetguy-u2799.html
Tue Dec 10, 2002 10:58 am
I just had some head work done and picked up my car on sunday.
when I picked up the car, it was idling super high at first, even higher than the normal warm-up setting. I figure it might just be really cold, but it hasn't come down.
As soon as I turn the key, it jumps up to 2000 rpms, and won't come down. When I disengage the clutch, the rpms drop down almost to 800rpm, but then jumps right back up to 1500-2000 rpm. sometimes it's unstable, wavering back and forth between 1200-1800rpm...
I've tried/checked the following things:
IAA screw adjustment (disconnected the TPS)throttle cable isn't too tight, has some play to it (so plate isn't sticking open)
what would cause such a high idle situation like this?
Dave
