DD725 »
https://forums.nicoclub.com/dd725-u91301.html
Tue Dec 11, 2012 10:15 pm
Ok walbro fuel pump was installed about 4 months ago, line completely deteriorated inside the tank so another feed line from pump to sending unit was replaced. After replacing all damaged and dry rotted fuel lines, my fuel pressure to the rail is 90psi, ummm wtf I think thats a little high. I was unaware that I would need an AFPR in conjunction with the walbro fuel pump. Is that my only option, AFPR or can I dial it down some other way. Also I bought the vehicle with the NEO rb25det swap already done and the previous owner has an adjustment knob on the return side of the line. Question is, does the vehicle need a regulated return. and both damper and stock regulator are still being used.
