ziggy682 »
https://forums.nicoclub.com/ziggy682-u3095.html
Tue May 10, 2005 3:56 pm
Should be possible as long as you have all the correct parts from the donor car. I just did poly bushings in my 91 Hicas, and I learned a thing or two. I never realized that the Hicas cars don't have rear toe links since the rear tie rods serve the same purpose. Also, since Hicas cars don't have the toe links, the rear spindles are different than a non-Hicas car. I didn't notice if the Hicas rear subframe has mounts for the toe link or not. If it doesn't, then you will have to swap rear subframes, spindles, add the toe links, and remove the hicas rack, etc.
Hmm, actually it doesn't really seem worth it to me. Why are you swapping out the Hicas system, instead if eliminating it? Is it just to save the weight, or do you have other reasons?
