ziggy682 »
https://forums.nicoclub.com/ziggy682-u3095.html
Tue Apr 20, 2004 9:21 am
Yeah, I can cofirm that normal AGX's will fit Hicas models. Hicas models came with slightly stiffer, slightly shorter springs than the other models. Really, the biggest difference in the Hicas suspension is the 21mm rear roll bar, which is significantly bigger than the other models.
You should have no problem putting any shocks onto a Hicas model. In fact, the factory service manual lists the same shocks for all models.
