Dori Dori »
https://forums.nicoclub.com/dori-dori-u2872.html
Sun Jun 29, 2003 3:45 pm
First of all, all you have to do is pull a fuse to disable it. Actually, any bad/false reading the hicas gets will shut it off and throw on the big red light on your dash. There will still be slight movement under hard cornering, but the hicas is not trying to do anything...it'll just feel like bad bushings (slop in the rear).
Second of all, your oversteer is probably not because of the hicas. When my car's hicas was/is enabled, it's much harder to get the car sideways b/c the rear wheels are fighting oversteer efforts. If anything, maybe you are having a hard time getting used to the much larger rear swaybar and quicker steering. Also, if your struts are blown (like mine were), your rear end will be impossible to predict.
Third, there are different hicas eliminators out there and different was to get rid of it. I have a hicas eliminator bar that I purchased from japanesemotorsport.com.au Cost me around $130usd shipped IIRC. It only took a couple days to get here fyi. What it does is get rid of the hydraulic box in the rear and replaces it with a bar. The toe links (more like rear tie-rods) slide into holes on either end of the bar. It also comes with a fluid return kit for the lines. Essentially, it'll do the same thing as the suggested welding (which I've never heard of until now), but that hydraulic box is heavy...and nobody likes uneccassary weight. Plus, if you change your p/s pump to a non hicas pump, you can pull out all the old lines and parts.
The border racing hicas eliminator kit that spl sells looks really cool and all, but the price is very high and I have one design concern with it. What it does is removes the bar and replaces it with brackets that hang down (from what I can gather from the pictures). Connected to the brackets are the new bars (one per side) that bolts onto part of the old bar (to retain toe adjustablity i think). The bad thing though is that I can see those brackes shifting under hard cornering load. If the brackets had a brace or something that would connect the two together, I wouldn't have a problem with it. I'm sure something can be welding to it as well. Still, it seems like a waste of time/money/effort to me.
Your other option is to swap the entire rear subframe from a non hicas car. I thought about this one, but since I work with floor jacks and jackstands in a garage, I said bah! Too much trouble to go through. If I had a lift and a couple of buddies to help, I may have gone this route.
