super amazing HIGH idle --- Please HELP!!!
silverQ
Car: 1991 Q45 180,000 mi
Hello I have a '91 Q45 and seems random but like 1/2 the time my idle shoots around 1.5k to 3k after warmed up in park or N (seems more common after harder driving). Also always when i first start the car cold it kinda seems to surge to like 2k and falls to the 1.5k like it should for 30 secs but it never comes down after 30 secs to like 700-800 rpm like it used to. This all started after I replaced some injectors that failed .. bit like I say the other 1/2 of the time it idles perfectly like it should. I have witnessed the idle drop almost mechanically like 300 rpms at a time to the proper idle a few times so I really don't think it's any bad hoses or connectors(maybe never can tell) .. but I checked them to be sure. Please help as this is making me want to push this normally amazing car off a bridge .. thanks
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Without any maintenance history, it is very difficult to comment.
Have you established all your vacuum hoses are intact, soft and supple, and not brittle?
1990Q45'r
Car: 1990 Q45
Sounds like air bypass valve might be dirty/sticky? Check to see if electrical connector Disconnected/loose?
DrewQ45
Car: 1990 Infiniti Q45
maxnix wrote:Without any maintenance history, it is very difficult to comment.
Sounds like Maxnix is getting feeling up his Q.... groping under the plenum... "So soft, so supple!"
squeefoo
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
Check your Throttle Position Sensor. Did you move it to put the injectors in ? Check connectors for corrosion?Do you have an FSM? Ohmmeter?
We need more concise info to help...
Raxephon
Car: '04 RX8...for the moment...
squeefoo wrote:Check your Throttle Position Sensor. Did you move it to put the injectors in ? Check connectors for corrosion?Do you have an FSM? Ohmmeter?
Just in case he doesn't........... '94 Q45 FSM http://phatg20.net/modules.php...d=203
silverQ
.. actually I pulled the plenum as I had like 7 bad total to replace. I have an OHM meter also but just seems odd as like it ran good before and runs good 1/2 the time now I have no idea whats up. Where's the valve and bypass located at? Thanks
Raxephon
silverQ wrote:.. actually I pulled the plenum as I had like 7 bad total to replace. I have an OHM meter also but just seems odd as like it ran good before and runs good 1/2 the time now I have no idea whats up. Where's the valve and bypass located at? Thanks
anlasak wrote: '94 Q45 FSM http://phatg20.net/modules.php...d=203
Its less than 40 megs.
Modified by anlasak at 12:09 AM 3/24/2006
Raxephon
AAC Valve Hoses
Raxephon
Vacuum Hoses
Raxephon
The 3 previous images are for the base model Q45.
Not included in the images is the vacuum line that runs to your brake booster.(That line/hose plugs into the plenum between the runners for cylinders 5 & 7)
Q451990
You might also check your ECU temp. sensor... if it's not getting a good reading it may think the engine is still cold and hold it in warm-up mode. You should be able to confirm if the ECU is telling the car to idle high by unplugging the AAC valve. If the idle drops, I would suspect that it's an input to the ECU that's the problem... if not I would think that it's a mechanical issue (like a vacuum leak, ect)
Just speculation on my part...
Heath
silverQ
Hello giving update with a fix for the problem.
When I originally removed the plenum to replace some injectors and then
reinstalled the plenum the small coolant hose running to the idle cam assy
(uses thermal wax to control idle) was kinked causing the high
idle. All is now well ..
Q451990
That would do it. Thanks for the update!
Heath
squeefoo
1999 Infiniti I30
silverQ wrote:Hello giving update with a fix for the problem.
Excellent! I really glad you wrote back and told us this. :dblthumb:
I've encountered many, many threads where they never write back and say what happened or what fixed it.
