SUNROOF Will Not Slide Open.. Still Tilts
dannym
My sunroof will not slide open, however it will tilt. I found this:
Service Bulletin Number: FC0005087Date of Bulletin: 9103Component: VISUAL SYSTEMS: GLASSSummary: SUNROOF WILL NOT OPEN-ALL 1990-1991 Q45 CM
Anyone have any more info?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
The cable is likely broken, youll need to buy a new sunroof assy... Start looking for one from one of our parted out Q45s. and 9096 Q will fit in yours.
Q45denver
Car: 1995 Infiniti Q45t
1990 Infiniti Q45
1998 Nissan Frontier
Will it work if you push up on it and give it a little assist? Might just be stuck or weak motor/sticking track.
dannym
Q45denver wrote:Will it work if you push up on it and give it a little assist? Might just be stuck or weak motor/sticking track.
Sometimes it will work but is slow and will stick/stop half way. I'll try giving it a helping hand and see what happens.
If you do get it open, wipe down the rails with a napkin.
Q451990
JebsNYCQ45
Car: 1994 q45
im almost done gutting my car....check your mail, it has the info...
