SUNROOF SUDDENLY STOPPED WORKING
Bluezman22!
Car: 2001 Nissan Pathfinder LE
2001 Pathy LE. Is there a security feature that disable's the sunroof? Also where is the fuse? I appreciate you people who take the time to reply.THANK YOU
Bluezman22!
ok, so I took my truck to the Goodyear service center here in Destin, FL to have my tensioner pully put back on (way back months ago when i did the alternator I forgot to tighten the nut on the front back ON right i guess and it came off, SHREDDED MY BELT and had happened right in front of Goodyear thank God.) Anyways, after I explained being a poor construction worker on the road,the good ole boy mechanic said he'd fix my break lights being on and yea IT WAS THE BREAK PEDAL STOPPER and they charged me $300 to put my tensioner back on btw. I noticed they had tightened my leads too to my battery ect. NOW,my sunroof doesn't work. It was working perfectly when I took it to goodyear service center!!! Where or what do i do to get it back working??? Its got to be a fuse or some security feature maybe(I do not have the FOB).....................THANK YOU PEOPLE FOR TAKING THE TIME OUT OF YOUR DAY AND REPLYING
Bluezman22!
NO ONE HAVE A CLUE? DANG. i THOUGHT SOMEONE WOULD BE ABLE TO HELP.
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
Well, there is a 7.5 amp fuse in the interior fuse box you can check.
Pg 198, Pg 374
http://www.nicoclub.com/service-manual? ... er/2001/el
Platinum04
Car: 2004 Nissan LE Pathfinder
When ever you disconnect the negative battery terminal you have to reset the sun roof. To reset the sunroof simply turn your key to accessory only, run the sunroof through the entire cycle by continuously pressing the open button until f the sunroof is fully open then again to the full close position. I hope this works at least it works for my 04 Pathfinder
04pathse
Platinum04 wrote:
Sun Aug 20, 2017 7:39 pm
But, he / she said the sunroof doesn't move at all when pressing the buttons.
barnaclebob
Car: 2001 Pathfinder LE
2011 Altima SR
I have a 2001 LE and have never heard of or had to perform this procedure...
OP I wish i could help. My only suggestion is to check the fuses.
QX4ME
Car: 02 Infiniti QX4 4WD
11 MB C300 Sports
06 Honda Odyssey
My 02 QX4 sunroof does not need resetting after I change battery. It could be different from year to year I guess.
