Sunroof stuck 12 m37
airmanhoward
Car: 12 M37-Current
08 civic lx sold
06 M35x Totaled
2000 S10 sold
Ford contour svt-sold
91 caprice-sold
90 & 93 maxima-sold
96 ford escort-sold
My sunroof is stuck in the tilted open position. Any suggestions on a solution?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
This is the procedure from the ESM for the '12 M. It doesn't say so, but many times the procedure won't take if you don't begin it in the full closed position:
INITIALIZATION PROCEDURE
If the sunroof does not close or open automatically, use the following procedure to return sunroof operation to
normal.
1. Press the tilt up switch and start the tilt up operation.
2. Release the tilt up switch once, press the tilt up switch again, press and hold the switch until lid pops up.
3. The glass lid moves slight toward tilt up direction then stop. (Press and hold the switch during this operation)
4. Release the switch again, and press the tilt up switch within the first 4 seconds. (Press and hold the
switch)
5. After 4 seconds, the glass lid will be automatically operated in sequence of tilt down, slide open and slide
close.
6. After the glass lid stops, release the switch 0.5 second later. (Press and hold the switch during this operation)
7. If slide switch operates normally, this initialization is done.
If it tries to move but won't, chances are the mechanism is jammed and it isn't a timing or electrical problem. If it isn't moving or making any noises when you press the switch, chances are it's a motor or harness issue. On M's the motor gets its power from the BCM, so there isn't really any separate fuse to check. At the motor connector, you should see ignition power on the beige wire, battery power on yellow, and a good ground on black.
Ilya
I've merged the threads Airman and deleted some posts to clean it up.
airmanhoward
Car: 12 M37-Current
08 civic lx sold
06 M35x Totaled
2000 S10 sold
91 caprice-sold
90 & 93 maxima-sold
96 ford escort-sold
Ilya wrote:
Sat May 01, 2021 8:23 am
Thank you kind sir. How are you liking Florida?
airmanhoward
Car: 12 M37-Current
08 civic lx sold
06 M35x Totaled
2000 S10 sold
91 caprice-sold
90 & 93 maxima-sold
96 ford escort-sold
Got it closed. Thank you. Never opening it again. :rotfl :rotfl
Ilya
airmanhoward wrote:
Sat May 01, 2021 8:49 am
Love it so far! Was actually in Largo today meeting my new pastor lol.
