Sunroof repair options
40Acres
My sunroof will open but wont close. One shop quoted me $200 labor to change the motor. Where is the best place to purchase the motor? Anyone recommend a shop in Los Angeles? I talked to Jerry at all import but hes 120 miles away.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
40Acres wrote:I talked to Jerry at all import but hes 120 miles away.
Sounds like a nice cruise to me for competent help. I drove 165 to Portland for a Senior Infiniti Tech when I needed one.
Look for a thread about adjusting the clutch, I believe by Q45tech.
A new motor form http://www.infinitipartsusa.com would be best as who knows how much clutch material it has left?
Modified by maxnix at 11:55 AM 3/22/2007
burijon
Car: Went to the darkside...acurazine
Q45tech
Motors rarely fail just the clutch starts slipping and needs adjustment.
However there is a cause for the slipping and that is higher friction resistance in the channels.............lack of lubrication and dirt build up.
Ozzie
Car: '90 Nissan 300ZX twin turbo - 2 seater
'99 Mitsubishi Legnum VR-4 Type-S twin turbo
'71 TA22 Toyota Celica (flat light)
'06 MK5 Golf tdi
and some motorbikes too
I find it strange that the roof will open, but not close, and require the motor to be replaced.
I vote for sunroof clutch adjustment, and a good clean of the rails.
Does the roof close if you give it a little assistance to start moving?
40Acres
The sunroof does close with assistance
DrewQ45
Car: 1990 Infiniti Q45
Mine does the same thing. And when I try to tilt it, only one side tilts up making it look lean. Seems like something binding in the mechanism. I believe the whole headliner has to be taken down to get to it. Too much work for me and the dealer charges like 8 hrs of labour.
