ctcunningham wrote:Hello Forum. I wanted to ask whether you might have any ideas on why the sunroof open/close switch will only move the window about 2 inches and then stops. I've read the Owner's Manual and it appears I am operating it correctly. Thanks CTC.
Welcome to NICOclub! Thanks for visiting the Armada/QX56 Forum!
I have had that issue happen on a few of my Infiniti/Nissan models. Every time I have had that happen, it went away as quickly and mysteriously as the issue had started. I know when it happened on my '08 Armada a week or so ago, it was right after I had the battery disconnected for a while because I was doing a mod. When I started it up the roof would only move 2" at a time, I ran to the store and then back to work. I forgot about the issue, then drove home, and when I was pulling in my driveway I remembered to try it again and all of a sudden it worked. If your roof doesn't "cure itself" I would suggest disconnecting the battery for a bit and then reconnecting and driving for a bit. Keep in mind if you disconnect the battery you will have to reprogram your radio and memory seats (if you have them). Good luck to you!
