DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Sun Feb 23, 2003 2:34 pm
Thanks so much for the post. It was a great reference, especially the line that says, "what finally worked was to slide that plastic edge piece forward, thus freeing the clips from the edge of the sunroof while leaving them on the headliner". Well, with your procedure it took 2 of us 7 or 8 hours to get the sunroof off the roof of the car, inspect it, and then reassemble, but we couldn't figure out how to remove the assembly from the car. When you took it out from the right rear door, was the sunroof angled forward or backward...that is, was it oriented from rear glass to bottom of front seats, or from bottom of back seat to top of front seats? We tried one way, and the tape measure indicated the other way wouldn't work either, even if we rotated the whole thing. Same year Q too, so I maybe measured wrong!Didn't matter too much...it quickly became really obvious the roof wasn't re-workable. The current owner recently bought it, and it was dead obvious that the previous owner had tried to fix it (stripping almost every fastener along the way), and had broken a lot of things in the process. The crossmember was in the trunk at the time of purchase! Looked like the worm gear is completely missing from the passenger-side track, so only 1 side moves when you turn the crank. Leaves a 1/4" crack on that side and just won't close.
