Sunroof motor make's noise but won't move .
hillq45
No matter which way you move the switche's it will barely move ANY IDEA's?
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Download a copy of the Factory Service Manual from here if you don't have one yet:
http://www.phatg20.net/modules...id=62
Read some threads which I got by doing a :
zerothread/215858http://forums.nicoclub ... d?id=52106
If it's not a simple cleaning /lubing matter:
Good Luck! Let us know how you make out.
hillq45
Hey, I did all that I could and it still won't barely move,I greased the track and it still seem's to be binding up on something.
lino
I'm sorry I don't have more to offer. Hopefully one of the more experienced guys will have some more imput.
hillq45
That's alright,I'll figure it out.Quick question how did you get your pic's on the page?
lino
Click on on the top of the page.
Now click on My SignatureNow where it says "Modify your signature" add the link of your pictures that you have hosted. I use Imageshack. Here's how:
On imageshack's homepage (www.imageshack.us), you can select the size of the pic you want. I usually choose the originlal size. If it's too big, you can choose a smaller size. Here's how to do it. Look at the red text:
hillq45
I got it thank's,now i'm going to take a pic of my int.
lino
Your car looks clean! clean! clean!
hillq45
Yea,it's very clean It came from Nevada no rust anywhere even underneth,I'm trying to download a pic of the int. right now but my Kodak software is giving me problem's.
Modified by hillq45 at 11:44 PM 4/23/2007
Hi Hill, welcome aboard!
I think I have a new OEM sunroof motor for sale... Let me know if you need it and I'll dig it out.
hillq45
I'll let you know.Thank's
Q45tech
Tighten your sunroof motor clutch at least twice before you ever consider repairing or replacing your sunroof motor.
hillq45
Will do,Thank's
hillq45
I tightend the nut on the back side of the motor alittle and it is still doing the samething,it won't go up or down but it goes front to back alittle when it's closed,you can see it move because it smashes the weather striping on the backside.
goody90q45
Car: 1992 Infiniti Q45 (sold)
Unbolt and remove it from its mount in the sunroof chassis, plug it back in and run it while holding the motor in your hand. If the motor operates in both directions then something is bound up in the sunroof assembly or the clutch needs more adjusting.
hillq45
I did that and it moves all 4 way's,how far should i tighten the nut ?And I can't figure out how to get the head liner out.
Modified by hillq45 at 10:49 AM 4/24/2007
hillq45
I took the track out and when you move the sunroof alittle black theaded rod come's out of the side of the track and i don't think that's normal.HELP!!!!!!!!!!!!!!!
hillq45
What's the biggest wheel I can put on a 93' Q45 without any rubbing?
lino
It would better to start a new thread for a different topic if you wan to get more replies.
If you do a , you fill find many threads with info on the subject. Some people have gone as high as 20s. I believe 18s tend to work best in the largest size.
Here are some threads to look at:
zerothread?id=223195http://forums.nicoc ... ?id=219861
