Sunroof leak/Sunroof rubber seal
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
apintoL
Car: Nissan Altima 2005, V6 SE 3.5, 4 doors.
Hi Nissan pals!!!
My car is a Nissan Altima 2005, V6 SE 3.5L.
I have a problem with my sunroof, it looks like the sunroof has a leak, I found moisture on the rear floor of the righ side. I think I need to change the seal of the sunroof and also clean the drain hose. I want to know, what is the exact name of this seal, rubber seal? weather strip? glass lid? can I get this seal individual or I have to buy some kind of seal kit?
If somebody had the same problem, please share your experience.
Thanks.
jdshift
Car: 2019 Nissan Altima
2015 Nissan Altima 3.5
2014 Infiniti QX70 S 5.0
Hello and Welcome!! Sorry for the late response but I believe it is called the Nissan sunroof seal weatherstrip. I have never had this issue since I only owned one Altima with the sunroof with no issues, somebody should chime in soon if they have had the same experience. Have you had a tech look at the seal to see if it needs replacing or service? Good luck!!
Return to “3rd Generation Altima Sedan (2002-2006)”
