meanmachine j-30 »
https://forums.nicoclub.com/meanmachine-j-30-u54853.html
Thu Jan 25, 2007 3:14 am
if it opens but won't close sounds like the switch. until i get it checked out , i would take the panel off where the switch is and use an allen wrench and manually close it by cranking the allen wrench , you can,t miss it, or while the cover is off or try unplugging the switch and soaking the switch with a solvent to clean off the corossion , let it dry then see if it works. thats what i did i had that problem 3 weeks ago-------------------------------------warning the sunroof tracks are fragile and brittle you strong arm it and you will be putting in another sunroof in.
