sunroof help
Mr.Q45a
Car: 1994 Q45, 1995 Q45a
Hi, I have just purchased a 1994 q45 with a 140k, the sunroof motor runs I can hear it. However, when the roof moves it does so intermittently if at all.
Thank you for your time and considerationKing
driverdriver
Car: NICO's longtime resident Canuck!!!
Could be a number of things: motor could be on the way out, the track could be not aligned or corroded, the belts that pull could be done.
The good news is that if you are DIY person, you can fix it yourself. It is labour intensive. The prcedure for a Q45 is somewhat the same as the J30.This link has more info: http://www.fuzzycats.com/j30_diy.htm
Go to the sunroof procedure pdf.
I'm sure the Q guys on this forum will chime in shortly with their suggestions.
