Well today I am on my way to work early this morning and since it is more than beautiful in the desert right now, I opened up the sunroof. GRIND GRIND HARSH NOISE GRIND GRIND HARSH NOISE..! WTF??!!
I keep trying to get it to fully open and then it just stops and wont respond. Not even the grinding noise... Wonderful. Freaking sunroof motor must be an expensive fix.
So I do a quick search - "infiniti sunroof stuck"
The first result was the winner from the G35Driver forum.
http://g35driver.com/forums/v36-diy/413 ... v36-s.html
It was another DIY that was far more intimidating than it was in reality.
When I finally got the headliner pulled down so I could tighten one or both of the screws and hope that was all it was, an EXTRA screw fell out of the headliner as well as some weird piece of plastic. It looks like either an installation tool of some sort, or a cover of something?? (see below)
Anyhoo - I was able to tighten one loose screw and put one screw back in to mount the motor. Put everything back together and NO MORE GRIND!
Then I had to do a reset of the sunroof position (another google search) and all is well! Took less than an hour and I am sure it saved me a few hundred bucks at least. AND I am looking forward to the vibration /rattle being gone!
